Saltar al contenido principal
El Whirlpool WRS588FIHZ es un refrigerador de acero inoxidable de dos puertas verticales con una capacidad total de 21,7 pies cúbicos. ft., con estantes de vidrio sin marco, iluminación LED, compartimientos ajustables en la puerta para galones y una fábrica de hielo instalada de fábrica. Está equipado con controles electrónicos de temperatura, alarma de temperatura, descongelamiento automático y cumple con ADA.
Preguntas 4 Ver todo
New Auger motor for ice maker
I just replaced my auger motor in my Whirlpool side by side. It worked for like a second then stopped working. It is a brand new auger motor. So any ideas? The cup button works and opens the chute but the new auger motor does not turn.
Update (12/16/24)
I found wires at the bottom of the freezer door that are cut. Could this be my problem with the icemaker not working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi @david24164
Please confirm the complete model number of the refrigerator?
There are 3 models beginning with WRS588FIHV i.e. WRS588FIHV00, WRS588FIHV04 & WRS588FIHV06 and they're not all exactly wired the same.
- de
@jayeff Hi, my exact model is WRS588FIHZ04. The one I picked was closest to that one on this site. Thank you for your time. David
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @david24164
Unfortunately I cannot find a download online for a WRS588FIHZ04 (Whirlpool part # W11575236) or for that matter a WRS588FIHV06 (part # W11610658) either, so I'm hoping that the tech sheet for a WRS588FIHV00 model uses the same diagnostic procedures to test the components in your model.
Enter the diagnostic mode a shown by the sheet and perform tests #44, #45, #47 & #48 and check the results.
If you find the problem and a different part needs replacing here's the parts list for your model. Locate the wanted part in the list and note the manufacturer's part number that is listed with it. Search online for the part number only, to find suppliers that suit you best.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Hi @david24164
The tech sheet shows a yellow wire going to the ice maker switch but no green/white wire but as I said, this tech sheet is not for your exact model.
Best thing to do is to join, solder and sleeve new wires between each end of the two broken wires (colour for colour) to bridge the break in each wire and check if it then works OK.
- de
Añadir tu respuesta
David estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 47
