Saltar al contenido principal
Disponible desde Mayo del 2020, El MacBook Pro 13" incorpora un procesador quad-core Intel de 8ª generación Core i5 e i7, y una gráfica integrada Intel Iris Plus 645. (Modelo A2289/EMC3456 con dos puertos Thunderbolt 3)
How do I replace the camera?
My camera is not working, can someone explain how to replace it please. The green light comes on but no image
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Start by resetting the NVRAM and SMC. If that doesn't help, then you know you have a hardware issue with the display. Replacing the camera itself on these models is not easily done. You would need to fully disassemble the display assembly and do some very delicate microsoldering. The more feasible approach is to replace the display assembly, but the displays on these can be pretty expensive. Here's a link to a display. Good luck!
Fue útil esta respuesta?
Puntuación 0
Is this the original display that came with the system?
Puntuación 0
You might be better off just using an external web cam when necessary as the 'repair' to fix the possibly damaged camera is a nightmare of a job when it comes to removing the screen glass and all to get to the camera part...... Have you checked inside that all the cables are in place..... Reemplazo del ensamblaje de pantalla de MacBook 13" con Dos Puertos Thunderbolt 2020
Puntuación 0
Añadir tu respuesta
Ronald León estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 22
Todo El Tiempo: 203
