Saltar al contenido principal
Water Damage, still usable!
Every since I got some water damage on my laptop, the GPU is no longer detected. If you push on the righ part of the case of the laptop, you can cause a short and immediate black screen shutdown. The laptop still works amazing for CPU only tasks and even mild gaming, the battery life obviosuly improved with no GPU😂
I've been living with this for around 6 months and now I'm becoming interested in troubleshoot the MOBO and soldering if needed to fix my laptop! any reccomendations?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@jacobfromerth my number one recommendation would be to start disassembling your laptop. Use this Dell G15 5515 Service Manual to work on your laptop. Remove the motherboard and then it's time to clean it. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide It was written for an Apple iPhone3G but all the points are still pertinent to your motherboard as well.phone. While you clean your board, check for any obvious damage, like burned or missing components etc.
Until it is cleaned, everything will only be a guess. Post some well-focused pictures of your motherboard with your question. That way we can see what you see Agregar imágenes a una pregunta existente and hopefully we can help you getting this back to "normal"
Imagen de iPhone
Guía
Reparación de los daños en un iPhone debido a la entrada de líquidos
Dificultad:
Difícil
1 - 2 hours
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jacob Fromerth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 53
