Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Documentación de reparación e información de servicio para televisores Hisense.
quise prender al rato despues pero no prendio mas solo luz
Hola buenas noches mi tele modelo 6150f de 58 pulgas. Un dia la apage la quise prender al rato despues pero no prendio mas solo luz que sera los led ? O que podria ser
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Si tiene sonido y te cambia el mismo al cambiar de canal si, son los led averiados
Fue útil esta respuesta?
Puntuación 1
@paolacerda you have not told us what you have checked and which light turned on. You also did not tell us if your TV still has sound.
The no video issue can be related to a bad backlight. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. You might make out some shadows or see the TV's menu etc.
If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Agregar imágenes a una pregunta existente for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Not sure about your TV model. Can you check and give us the complete model number. I am not sure about a 58 inch TV but maybe it's a 55 inch. I would expect the number to be something like 55H6150F or similar
Translation
@paolacerda no nos has dicho qué has comprobado y qué luz se ha encendido. Tampoco nos has dicho si tu televisor sigue teniendo sonido.
El problema de la ausencia de vídeo puede estar relacionado con una mala retroiluminación. Una comprobación sencilla sería oscurecer la habitación y encender el televisor. A continuación, utiliza una linterna y dirige la luz hacia la pantalla en distintas zonas. Puede que distingas algunas sombras o veas el menú del televisor, etc.
Si es así, es que ha fallado la retroiluminación. Si no ves nada, desenchufa el aparato y retira la tapa trasera. A continuación, comprueba visualmente las placas para ver si hay algún componente dañado evidente. Comprueba todo el cableado y desenchufa los cables y vuelve a enchufarlos, asegúrate de que están bien asentados. Publica algunas imágenes de todas tus placas junto con tu pregunta. Utiliza para ello esta guía [guía|21499] para que podamos ver lo que tú ves. Es posible que se trate de un problema de la placa de alimentación o de la placa T-con.
No estoy seguro del modelo de tu televisor. ¿Puedes comprobarlo y darnos el número de modelo completo? No estoy seguro de que sea un televisor de 58 pulgadas, pero tal vez sea de 55 pulgadas. Yo esperaría que el número fuera algo así como 55H6150F o similar.
Puntuación 0
Añadir tu respuesta
paola cerda estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 34
