Saltar al contenido principal
El Honda CR-V es un crossover compacto fabricado por Honda desde 1995. Como utiliza la plataforma del Honda Civic en una carrocería SUV, se le llamó "CR-V", que significa Comfortable Runabout Vehicle.
Bagaimana mengatasi over heat pada mobil saya
Over heating
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi @adipraja
What is the year and engine size of the vehicle?
Have you checked if the coolant level in the radiator and reservoir are the correct level.
Try the following to check if the coolant pump and coolant thermostat are working OK.
Beginning with a cold engine, with the transmission in Park (AT) or Neutral (MT) and the handbrake firmly applied, start the engine.
Open the hood and then remove the radiator cap.
Once the engine warms up you should see the coolant in the radiator neck begin to swirl and expand.
If it does then this indicates that the thermostat has opened and that the pump is working. Switch off the engine as you don't want to coolant to flow out of the radiator.
If it doesn't, and the temperature gauge shows that it is overheating then it could be a faulty thermostat or pump. More likely a faulty thermostat.
Be safety aware when you do this as the engine is running!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Adi Praja estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 6
