Saltar al contenido principal
How to repair screen
How to repair the screen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The issue with TVs isn't that they can't be repaired; the LCD usually costs as much as an entire TV :/. Even when the TV is current, the panel tends to be a "total loss" failure.... It gets worse when they become last year's model, without fail. Unless it's an LED array failure you can recover from with a set of donor strips, I've never seen anyone successfully repair a TV with panel issues.
Your best bet is to take the TV apart and look up the panel number; you might get lucky. That said, TVs are generally not cost-effective for panel replacements, and you're usually better off selling the parts that still work to offset the replacement cost.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Abebaw Simachew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 51
