Saltar al contenido principal
Repair and disassembly guides for Lexmark printers.
Lexmark B3442dw Paper Jam Front - Error with no Paper
I ordered this printer 3 months ago and Lexmark support has come back to say it's unfixable. But from the first boot up it registers a paper jam (front).
No paper has ever been put in the printer.
Does anyone have any idea what sensor I should check?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
@switchhear let's see if our printer guru @nick has any idea about this.
- de
@oldturkey03 I'll have to look at mine and see where the sensors are before I scored a MS621 to replace a temperamental HP. There's a few similar MS variants of it with the same firmware tweak I mentioned on the CS431.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
With that out of the way, here's the issue: The sensor inside the toner compartment is probably broken and needs to be replaced, or there is paper under the cover, which can be cleared by taking the two screws marked in red (use a stubby screwdriver unless you want to remove the side panels and top cover -- there is no working room without removing the top panel on this model). Use a small object like a toothpick to see if the sensor moves freely. If it does not, the sensor is broken and needs to be replaced, as it is creating a false jam by being stuck in the closed position too long.
The sensor is towards the bottom of the printer and is a bit tricky to replace AND requires significant disassembly :-(. I have attached photos to show how much of the printer is inaccessible from the bottom with this particular unit:
Here is the SM for the printer:
Lexmark B3340 B3442 Ms331 Ms431 Ms439 M1342 Service Manual
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
@oldturkey03 this also applies to the MS331/431. It has a firmware tweak to use the MS toner and reject the "B" toner; it uses the same parts as well for the most part (except the controller which may have a different part number).
The "B" variations were pointless IMO, but they were still released. They should have sold them with the MS model number as "GO line" units. It just creates confusion around the toner and serves little to no benefit. Had I known the B3442 was a firmware tweaked MS431, I'd have went for the MS431.
- de
Appreciate it so much. Checked the sensor and it's squeaking when moved and takes a bit of effort to move it. Blew it out anyways with the air gun and nothing so most likely looking at replacing the sensors. Still getting
Paper Jam Front 200 91B as the error message. Can't even clear it off the screen just keeps flaring back to that.
- de
@switchhear Mine came back but I jammed it on purpose to locate the sensor.
- de
@switchhear Maybe if you can take it out and put something like dry lube on it it'll help? I'd still buy one and expect failure. Wet lube isn't going to be great for a part like this.
- de
Añadir tu respuesta
Switch_heart estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 53
Todo El Tiempo: 618
