Hi @abl1571
If there's no indication of power at all on the washer, check if the noise filter p/n 6201EC2002V is OK. (supplier example only to show part, possible cost and location of component) as I think that it incorporates a fuse as well.
If the fuse has blown then there's always a reason for this to occur as generally fuses don't fail of their own accord so perhaps if you just replace the fuse (look for voltage/current ratings on fuse itself) get 2 or 3 just in case it blows again. If it does then further testing will be required to find the problem.
If you wish to replace the entire part, search online for the part number only to find suppliers that suit you best.
If the washer indicates that there's power, below is an image showing how to run the diagnostics that may help. I'm not 100% sure that this will work as it is for the model range just before your model series but usually the manufacturer doesn't change things too much. Worth a try anyway if it helps to find out what's wrong.
If you find the problem and it is a faulty part that needs replacing, here's the parts list that is useful. When you have located the wanted part in the list, you'll find the manufacturer's part number listed as well as the part supplier's part number. Search online for the manufacturer's part number to find suppliers.
(click on image)
3 comentarios
Hi @abl1571
Please confirm the model number of your washer?
The number that you posted is a part number for a component part of the washer and not the model number.
- de jayeff
Model Number WT7305CV
- de ABL_1571
I will also add...we checked breaker, plug in, etc.
Frustrated because it is not even 4 years old.
- de ABL_1571
