Saltar al contenido principal
The Dell OptiPlex 7010 MT is an office-oriented desktop PC. It comes with a third-gen quad-core Intel i5 or i7 CPU. It has 4 DIMM slots, 10 USB ports, two hard drive bays, and two DVD drive bays.
Preguntas 15 Ver todo
Why my desktop keep on and off continuously without able to use it.
I need to unplug power cord for few minutes, then only it can start normally.
After i shut down without unplug cord, it won't able to start again but keep on off and on off don't stop
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @melvintham
Try a power refresh in case the BIOS has become corrupted and is preventing a normal start.
Here’s the procedure:
a). Disconnect the AC power from the PSU and then open the PC case and remove the coin cell RTC battery from the motherboard.
Here’s the owner manual for the PC. Go to p.15 to view the procedure to remove the battery. Note the orientation of the battery for when you have to re-insert it. It is +ve on top - marked on battery. When the battery is removed, use a DMM (voltmeter function) to measure the battery’s voltage. If it is <2.6V DC (or if it is >4-5 years old), replace it. Usually the battery is a CR2032 Lithium coin cell battery that is available most everywhere e.g. supermarkets. Check the battery type, printed on the battery itself, to verify the type number in case it is different.
b). Press and hold the PC Power On button for 30 seconds and then release it. This will restore the BIOS back to the factory default settings.
c). Reinsert the coin cell battery (or replacement battery) - remember the orientation!
d). Reassemble the PC and reconnect the AC power to the PSU.
e). Turn it on and check if it starts OK. If it does, there may be a message on the screen about the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected, the message won’t appear the next time that it is started.
Fue útil esta respuesta?
Puntuación 1
What's the last thing you changed before the problem start to occur, any change you made, any water inside? Did you tried the basics like look for visuals problems and clean. Do you have any loose inside (ram,cable)? Other then that I would guess power supply issue. Sadly I don't know how they work. Maybe someone with power supplies experience will answer to your question
Puntuación 0
Añadir tu respuesta
Melvin Tham estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 23
