Hi @abelnatera95910
Try a power refresh and check if that resolves the problem.
a). Disconnect the power from the PSU and then open the PC and remove the RTC coin cell battery from the motherboard.
Here's the owner manual for the PC. In the manual there are images of the motherboard layout, depending on which model variation you have, showing the location of the coin cell battery.
When the coin cell battery is out, measure its voltage. If it is <2.5V DC or >4-5 years old, replace it. The battery type number is printed onthe battery.
b). Press and hold the Power on button for a full 30 seconds and then release it.
c). Reinsert the coin cell (+ve side up as marked on the battery).
d). Reassemble the PC and reconnect the power to the PSU, turn it on and check if it works OK.
If it works OK there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to its default state by the above procedure. Once the date and time have been corrected, the message won't appear the next time the PC is started. Also any user definable BIOS settings that were changed by you to suit whatever operating requirements were needed will have to be changed back again as well.
If you don't have a Dell Optiplex 7010 what's the make and model number of your PC?
Pruebe una actualización de energía y verifique si eso resuelve el problema.
a). Desconecte la alimentación de la fuente de alimentación y luego abra la PC y retire la batería de tipo botón RTC de la placa base. Aquí está el manual del propietario para la PC. En el manual hay imágenes del diseño de la placa base, según la variación del modelo que tenga, que muestran la ubicación de la batería de tipo botón. Cuando la batería de tipo botón esté agotada, mida su voltaje. Si tiene <2,5 V CC o >4-5 años, reemplácelo. El número del tipo de batería está impreso en la batería.
b). Mantenga presionado el botón de encendido durante 30 segundos completos y luego suéltelo.
c). Vuelva a insertar la celda de moneda (con el lado +ve hacia arriba como está marcado en la batería).
d). Vuelva a ensamblar la PC y vuelva a conectar la alimentación a la fuente de alimentación, enciéndala y verifique si funciona bien.
Si funciona bien, puede aparecer un mensaje indicando que la fecha y la hora son incorrectas. Esto es normal ya que el BIOS se restableció a su estado predeterminado mediante el procedimiento anterior. Una vez corregidas la fecha y la hora, el mensaje no aparecerá la próxima vez que inicie la PC. Además, cualquier configuración de BIOS definible por el usuario que haya cambiado para adaptarse a los requisitos operativos necesarios también deberá volver a cambiarse. Si no tiene una Dell Optiplex 7010, ¿cuál es la marca y el número de modelo de su PC?
