Refrigerator drain tube clogged
Refrigerator drain tube clogged. How to replace it?
My Model Number is WRS322FDAM04
Es esta una buena pregunta?
Where is it blocked?
You can easily replace the drain tube extension at the bottom, underneath the refrigerator.
Here's a link that has a video that shows how to replace the extension tube. Perhaps check to see if it is blocked there.
If you have to replace the tube, search online for W1152417, to find suppliers that suit you best.
However if the drain tube is blocked between where it is connected to the drain hole underneath the evaporator unit inside the freezer and where the extension tube connects to it under the refrigerator, it will be difficult to replace.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 21
