Why is my computer running out of power So fast
When I'm done charging and then I left it tomorrow even though I Left it off it keep Running out of power help
Es esta una buena pregunta?
Seems as though there's a problem with the battery in the laptop.
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as seen in the report.
For a good battery they should be nearly the same value.
You can work out the condition of the battery as a percentage by using the formula: Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery is <35% you may wish to consider replacing it.
Here's the hardware maintenance manual, for the laptop.
Go to p.70 and then to p.84 to view the procedure to remove/replace the battery in the laptop.
Here's the parts list for the laptop. Click on Select Commodity > Rechargeable batteries Internal(8) to find the spare part numbers for all the batteries that are compatible and can be used in the laptop (one of these numbers may also printed on your battery). Search online for the part number only to find suppliers that suit you best.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 28
