Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cooling fun not working
When I on my pc I see a black screen saying cooling fun not working properly
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Hi @kalimitchell
What is the full model number of the laptop and shown on the product information label on the bottom of the laptop?
Knowing this ensures that, if necessary, the correct replacement part information can be provided.
- de
Hp pavillion 2000
- de
most of the time it has too much dust or cat hair inside. you need to clean the cooling system or at least remove some of the dust. The fan can be damaged if stuck too long but often makes a lot of noise first.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@samwelmhilu identifying a computer should not be this difficult. There is usually a label on the bottom side that will tell you what computer you have. Anyhow, we just have to assume that your computer is a HP Pavilion dv2000.
Use the Maintenance And Service Guide Pavillion DV2000 page 191 to remove and clean your fan/heatsink assembly. Once you are done with either replacing or cleaning it, you do want to go ahead and apply new thermal paste. Here is a generaic guide on how to do that Cómo aplicar pasta térmica
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kali Mitchell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 249
