My purifer unable to fill water in its tank?...why?
Es esta una buena pregunta?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 39
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. Agregar imágenes a una pregunta existente
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
- de oldturkey03
