Saltar al contenido principal
Why is my new battery overheating. Replaced the previous battery
Replaced previous battery not holding the charge long enough. All filters cleaned or replaced motor unit blew out. Reassembled. Using it this morning and battery got very hot and run out of charge.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Batteries get warm/hot when passing a lot of current either charging or discharging because of the internal battery resistance.
If you are using it and it gets very hot, either the battery is bad or the device is drawing too much current. For a vacuum, it could be a bad motor, a very tight brush roller, or plugged airways.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mervyn Tannahill estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 235
