My laptop Motherboard Heat
My samsung laptop switch off automatically and doesn't switch on until now and also it come another problem the motherboard heat a lot why?
Es esta una buena pregunta?
@themediaso47697 start with the overheating issue first. Disassemble your laptop, clean the air vents and the inside of you computer. Then check teh fan and consider replacing it. You also want to repaste the thermal paste on your processor since it is most likely no longer doing it's job.
Use this guide Samsung NP R580 JBB2 Cooling Fan Replacement for the fan and the heatsiink. To apply new thermal paste use this generic guide Cómo aplicar pasta térmica
Once cleaned, new fan and thermal paste applied, check your laptop and see if it comes on. It is possible that you may have thermal damage to either the CPU or other parts on your computer. You have to deal with cooling first, then troubleshoot for whatever does not work. Let us know what you find out.
Guía
Dificultad:
Moderado
5 - 20 minutes
Guía
Dificultad:
Difícil
20 - 45 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 7
