Led bulb 120wt repair
Led light bulb 💡 repair
Es esta una buena pregunta?
@hamzajutt you're really not giving us much to work with. It would be nice if you would at least tell us what your bulb does, what happened to it and what you have already checked.
Here is a generic answer. Take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. You need to check the LED's, the capacitors as well as the LED driver. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Agregar imágenes a una pregunta existente
GuÃa
Dificultad:
Muy fácil
2 - 5 minutes
GuÃa
Dificultad:
Moderado
30 minutes
GuÃa
Dificultad:
Moderado
Fue útil esta respuesta?
Ultimas 24 horas: 4
Ultimos 7 dÃas: 15
Ultimos 30 dÃas: 163
Todo El Tiempo: 440
Charging LED bulb repair
- de Satya Narayan sahoo
Yes my led bulb is dead
- de Ashvini Vaidya
