Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzada el 23 de junio de 1996, modelo NUS-001, la N64 es la primera consola de juegos de 64 bits de Nintendo y, hasta el lanzamiento de la Switch, la única (la GameCube, la Wii y la Wii U podían realizar cálculos de punto flotante de 64 bits, pero esta no es una arquitectura de 64 bits real).
Incredibly dark image - help!
Hi,
Found my old N64 tucked away and trying to get it to work.
It’s on a SCART cable, and I get audio just fine, but the image in the screen is INCREDIBLY dark. Like not there at all. With brightness/contrast settings cranked on the TV you can just about make out the image.
I’ve re-seated and cleaned all cables and the expansion pack, and tried multiple games
Any ideas?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios
Hey there, are you trying to play your N64 on an HD TV or using a CRT TV?
- de
HDTV.
Thanks
- de
Have you tried using different games, and tried cleaning the N64 cartridge’s pins?
- de
@spawn2048 how do you connect your N64 to your HDTV? Have you tried an older TV? what make and model is your TV?
- de
@jmehnert yes, as stated in the original question…
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
I advise to clean the AV port first. If that didn’t worked, then replace the AV cable for a new one. If that didn’t worked, then try the console on a different TV to determine if there is something wrong with the console. If the image is like still super dark, then open up the console and clean it all (also the cartridge pins on the motherboard) and try again.
Could you also share some pictures regarding how the console is connected to your TV?
Please let us know how it goes!
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Bit the bullet and bought a new cable. Now on AV rather than SCART and working fine. So either broken cable, or broken SCART port on TV
- de
Hi!
Alright. Probably the cable (in most cases). You could try the SCART port with the new cable. Could be the SCART adapter as well. Good to hear that all is ok now :)!
- de
Añadir tu respuesta
spawn2048 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 33
Todo El Tiempo: 988
