Removing bottom drive cover ez walk mower
How do I remove bottom drive cover on ez walk mower. I have 1 bolt out which is all I can find. I don't want to reef on it and break it.
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 19
Are you talking about the plastic drive belt cover on top of the mower deck with one bolt right about in the middle of it? Here's a link to an exploded view .
https://www.ereplacementparts.com/crafts...
- de moe_r
yeah, i got the bolt out but didn't want to break any tabs off by pulling it too hard. do you just pop it off.
- de BLAIR SCHIMMING
I believe that if you push on the front of this cover while gently lifting, a tab will release at the front of the cover and you should be able to lift it off. It appears there are two tabs at the rear of the cover that should slide out once the front tab is released.
- de moe_r
