Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Las torres medias ATX tienen la misma construcción general y partes que otras torres de ordenadores de tamaño medio
Message every time the PC is turned on
Hi, every time I turn on the PC this message appears "Please enter setup to recover Bios setting.
When Raid configuration was bulit,ensure to set SATA configuration to RAID mode.
Press F1 to run SETUP."
What should I do to solve this problem every time I start the PC?
Update (04/11/24)
Solved I changed the bios battery and solved the problem.
Thanks for the reply.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Hi @ale60137,
What is the make and model number of the PC or the motherboard if a custom build?
Was the PC setup to be used in a RAID configuration or not, before this problem occurred and if so was it working OK?
Was there any general power failures to the premises where the PC is located, when the PC was turned on and working, just before the problem occurred?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Check BIOS battery, it needs to be at least 3.6
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
ale estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 28
Todo El Tiempo: 433
