Por qué mi laptop no prende?
Mi laptop no prende , probé el cargador y está bien
Es esta una buena pregunta?
@serlam21 you are not giving us enough information. you need to consider to letting us know if anything happened to your phone? Did it just stop charging? what have you checked and what have you tried to fix it?
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. If you don't get that voltage check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it.
Once you have your laptop opened up, take a couple of pictures of the motherboard etc. Post those with your Question.That Way we can see what you see and hopefully will get a good solution.s
Take lots of well focused pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://es.ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
@serlam21 no nos estás dando suficiente información. tienes que plantearte hacernos saber si le ha pasado algo a tu teléfono? ¿dejó de cargar? ¿qué has comprobado y qué has intentado para solucionarlo?
Primero debes comprobar tu fuente de alimentación. Asegúrate de que tiene los voltajes adecuados. Comprueba que los conectores no estén doblados, etc. Después, comprueba el puerto de carga. Límpialo de cualquier residuo, etc., utiliza unas bocanadas de aire para limpiarlo. Asegúrate de que no hay corrosión, restos, etc. que impidan que funcione. Si nada de esto funciona, consigue un amperímetro y comprueba si tu portátil consume algún amperaje del cargador.
También puede que tengas que plantearte sustituir la batería. Una batería agotada ya no se puede cargar. Mide el voltaje en el conector de la batería con el cargador enchufado. Si no obtienes ese voltaje, comprueba el cable flexible que sale de la placa de carga. Asegúrate de que está bien asentado y no tiene roturas ni otros daños.
Cuando tengas el portátil abierto, haz un par de fotos de la placa base, etc. Así podremos ver lo que tú ves y, con un poco de suerte, encontraremos una buena solución.
Haz muchas fotos bien enfocadas. Cuando hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
Fue útil esta respuesta?
Con el cargador conectado, Prueba a mantener pulsado el boton de inicio 15 o 20 seg a ver si reacciona.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 15
