What makes the ABXY board to stop working?
One of my 3ds systems (new 3ds) used to work normally, but all os sudden it didnt turn on anymore (only if plugged in but didnt charge)
I took it to some repair shops but every shop told me that the repair wasnt worth it since the system needed a new motherboard.
I left the 3ds aside for some time, but didnt give up and kept searching online for a solution. After a long time i found that a possible solution was changing the ABXY board.
Since it was a cheap solution i decided to try it out. And it Worked!! But not for too long :( after one day or two it stopped working again.
So, what may be causing the abxy board to stop working? I want to fix my 3ds :(
Es esta una buena pregunta?
I would start with this guide and look for damage then give us images to give you a better diagnosis and hopefully a working 3ds in the end.
Nintendo 3DS 2015 C-Stick Replacement
Agregar imágenes a una pregunta existente
- de Markus Norstrøm
So after changing the ABXY board again, my 3ds is now working and charging.
Later, i will turn it off an on again to see if it keeps working.
- de JAFA13245
