Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Que debo hacer si mi celular se mojó?
Hola mi celular se cayó al agua y estaba encendido, funcionó bien por una hora, sin nada. De la nada le salieron unas rayas en la mitad de la pantalla. Apago la pantalla sale bien y a unos segundos de uso se reflejan las rayas. Que debería hacer? No sé si apagarlo pero tendo miedo que no vuelva a encender. Vi gotas de agua en la cámara
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Aquí en este hilo, tienes algunos consejos. Espero te sirvan.
https://es.ifixit.com/Respuestas/Ver/678...
Fue útil esta respuesta?
Puntuación 2
@lucybetancourt As my colleagues rightfully stated, your phone needs to be checked. I just prefer to give you more options to try to fix your phone. I am a strong believer in the importance of empowering people to fix their own devices.
For now, you will need to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. You will need to disassemble your phone. since iFixit does not yet have guide for that, use something like this video
Once it is disassembled, you must remove all EMI shields from your circuit board. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide Even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Repair is War on Entropy!
Translation
@lucybetancourt Como bien ha dicho mi colega, hay que revisar tu teléfono. Simplemente prefiero darte más opciones para intentar arreglar tu teléfono. Creo firmemente en la importancia de capacitar a las personas para que arreglen sus propios dispositivos.
Por ahora, tendrás que dejar de intentar cargar, sincronizar o utilizar tu teléfono. Esto puede empeorar la situación y dañar aún más el teléfono.
Lo siguiente que hay que hacer es limpiarlo. Usted tendrá que desmontar el teléfono. desde iFixit aún no tiene guía para que, utilizar algo como este video
Una vez desmontado, debe quitar todos los escudos EMI de la placa de circuito. Después de quitarlos, limpie toda la placa, conectores y todo con +90% de alcohol isopropílico. Sigue this guide Aunque fue escrita para un iPhone 3G de Apple, todos los puntos siguen siendo pertinentes para tu teléfono. Mientras limpias la placa, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
Cuando esté bien limpia, sustituya la pila. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor sería limpiarla con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho esto, vuelva a montar el teléfono y evalúelo de nuevo. Hasta que no se limpie, todo serán suposiciones. Es posible que tenga una pantalla LCD defectuosa y que la sustitución del conjunto de la pantalla pueda solucionarlo. Incluso con todo esto, los daños por agua sólo tienen una pequeña posibilidad de ser reparados por completo, pero al menos puedes intentarlo.
¡La reparación es la guerra a la entropía!
Puntuación 2
Añadir tu respuesta
Lucy Betancourt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 137
