Laptop usb ports not working
Laptop usb ports are not working
Es esta una buena pregunta?
Hi @nkhahle
Plug in a mouse or any other USB device that shows if power is connected e.g. mobile phone, flashdrive with a light etc, into the USB port and check if you get an indication of power from the port, e.g. mouse laser light turns on or a charging indication on a mobile phone
If nothing then check the USB power management setting in Device Manager hasn’t disabled the ports.
Go to Device Manager → click on the + sign to the left of Universal Serial Bus controllers to expand the list → right click USB Root Hub → Properties → Power Management and uncheck “Allow the computer to turn off this device to save power” > OK
Do this for all USB Root Hub entries shown as I don’t know how many there are in your laptop and which ones may be associated with the faulty USB ports.
Then restart the laptop in the normal manner for the changes to come into effect and check if the USB ports work OK.
Here’s an image what it looks like in Device Manager. This is from my desktop computer so the hardware is different but the USB entries and where to find them will look similar.
(click on image).
To get into Device Manager if Win 10 is installed, press the Win key and the x key (both together) and then click on Device Manager in the menu options that open.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 17
