Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Oppo A37 A37fw 16GB viene con 2GB de RAM. El Oppo A37 ejecuta Android 5.1 y funciona con una batería no extraíble de 2630 mAh (según lo dicho por Oppo ;-). Lanzado por primera vez en abril de 2017.
In my oppo phone not run updated youtube
This phone isn't compatible with this app written when I open youtube app
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 24
7 comentarios
Problems Update
- de
YouTube not update in oppo a37f
- de
YouTube nhi chalra
- de
how to fix coloros recovery
- de
Mere phone m youTube download nahi ho rha hai
- de
Mostrar 2 comentarios más
Agregar un comentario
5 Respuestas
Respuesta Más Útil
You should make use of the browser version of youtube. It allows for a slightly lower level alternative.
Fue útil esta respuesta?
Puntuación 4
i have same problem, then i realize it's cause by full memory and storage.
apps need storage to save it, but need much memory to run.
Puntuación 2
Hi @ayushmanraj,
Have you tried updating the phone's system software in the phone, you didn't say?
Go to Settings → Software update. Ensure that the phone is online when trying this.
If the phone's software is the latest version, then unfortunately you may have to revert back to the previous YouTube app that did work.
Puntuación 1
okay the reason behind the incompatibility is an outdated Android version. The Oppo A37 runs on Android 5.1 which is quite old. with that the newer versions of YouTube app may no longer support this version. possible solutions to the problem try this;
  1. install an older version of YouTube app via third party APK sites
  2. give a try to YouTube Go which is considered a lighter version of the app
  3. lastly use YouTube in a browser instead of an installed app
Puntuación 1
Your phone isn't compatible for this app. You also download a Vidmate app to run as youtube. This app is same working as youtube
Puntuación 0
Añadir tu respuesta
Ayushman Raj estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 129
Todo El Tiempo: 2,651
