Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Reparación y soporte para la tarjeta de memoria de Sega, la Visual Memory Unit (unidad de memoria visual) para Dreamcast.
Horizontal Lines on screen, any ideas?
Imagen
Hello
I am new to repairing so bare with me.
As shown in the image, the screen has horizontal lines and i have no idea on how to fix it. I have taken it apart several times and given it a very thourough clean. The circuit board looks brand new, soldering is fine, pathways are fine. The only thing i can think of is that there is something wrong with the screen itself and the rubbery things that the screen is attatched too. I have no clue on how to fix something like that and have found no repairs online for it.
Any help would be appreciated.
Cheers
Tim
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hi
Thanks for the reply and advice. I have tried everything you suggested but still to no avail, but i did find out that you can remove those rubber strips from the screen very easily to clean them. I have attached (not great) pictures of my VMU to see if anyone may have any ideas in the future.
Cheers
Tim
[image|3240895] [image|3240894] [image|3240893] [image|3240891]
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hey there,
It looks like an issue with the connection from the screen to the board. The only thing that's really holding the screen to the board is the plastic case, so try tightening the case screws a little bit. Otherwise, try removing the screen (It's not soldered in place and should pull right off) and cleaning the zebra strips and contacts on the screen and board with 90% rubbing alcohol.
best of luck to you
Fue útil esta respuesta?
Puntuación 1
Hi
Cheers
Tim
Imagen
Imagen
Imagen
Imagen
Puntuación 0
Añadir tu respuesta
FanDango estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 34
Todo El Tiempo: 790
