Saltar al contenido principal
Una computadora portátil asequible de gama media vendida por Acer a mediados de 2015. Esta computadora portátil viene con una tarjeta gráfica Nvidia 940m, una CPU Intel i5-5200U y una pantalla de 1080p.
Preguntas 29 Ver todo
Can I swap the LCDs of this laptop to a Acer V5 431?
Can i swap the LCDs of these two?? An Acer E14 and Acer v5 both has the same screen size but different connectors. The E14 has 30pin for it's LCD while V5 has 40 pin i was thinking if its okay if i also move the flex connector as well is it possible??.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @markangcos
You can't just interchange 30 pin LCD screens and 40 pin LCD screens that easily.
The panel's operating specifications e.g. LCD panel's operating voltage (Vcc) value, backlight enable voltage signal value, LED power requirements and LVDS cable wiring pinout connections were chosen as these will work with the motherboard that the panel was originally connected to.
If you wish to check what these are, search online for (insert make and model LCD panel¹) datasheet for both LCD panels, to hopefully find them.
If you do find them, then they will have the specifications for the panels so that you can compare if they are the same or not.
If their operating specifications aren't the same, then it won't work and if you try anyway you may end up damaging the LCD panel, the motherboard or both.
If it is only the wiring pinout connections that are different you may be able to adapt the cable so that LCD panel pinout matches the LVDS connector pinout on the motherobard that it is going to connect with.
¹ Usually the make and model number of the LCD panel can be found on the back of the panel itself somewhere.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Mark Angcos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 28
