Saltar al contenido principal
El Meta Quest 2 (antes Oculus Quest 2) salió a la venta en octubre de 2020 y es el sucesor del Oculus Quest.
Preguntas 169 Ver todo
Water damage to right controller
My right controller got submerged in water for maybe a second or two. So I took out the battery and left it to dry, hoping the water wasn't inside the controller.
It's now not working.
And whenever I turn the controller on it vibrates for a short amount of time and then stops.
Am I screwed or is this fixable?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @mgd99100
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the controller's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your device and then remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the controller and clean any affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the controller might possibly work correctly again.
Here is the ifixit Meta Quest 2 repair guide that may help.
If this process seems too daunting, take your device to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later as it isn't going to get better by itself.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
M.G.D estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 45
