Porque tengo una linea blanca vertical
sony television KDL-40EX725
Es un televisor viejo con una linea blanca en medio vertical esta molesta la visual pero no es 100% blanco se ve la imagen de fondo
Es esta una buena pregunta?
@freddyosses going by your description I would assume this line to be like 1-11/2 inches in width. If so, this comes form the LCD driver boards. Those are the long skinny boards that are the last boards on your tV that connect directly to the LCD display. There will be a ribbon cables that corresponds to the exact area of your screen where this line is. With the TV on, try to push the ribbon cable gently onty the display panel. If that changes this line you know that the issue is the connection between the cable and teh panel. This can't be fixed but sometimes wedging something between teh TV housing and that ribbon cable maintains enough pressure for them to make contact.
If it does not change anything, then the issue is most likely the driver board. There are no schematics and the boards can't be changed but a DIY'er like us. Check for any burned looking components. Maybe we can find one and try to fix that. Otherwise you will require a new screen since this board is considered part of the screen.
If this is to confusing or if the following translation does not make any sense, add some pictures of your boards and the complete back of the TV (cover removed of course) so that we can see and try to guide you further,
Translation
@freddyosses siguiendo tu descripción yo asumiría que esta línea es como de 1-11/2 pulgadas de ancho. Si es así, esto viene de los tableros del conductor del LCD. Esas son las placas largas y delgadas que son las últimas placas en su TV que se conectan directamente a la pantalla LCD. Habrá cables de cinta que corresponden al área exacta de su pantalla donde está esta línea. Con la TV encendida, intenta empujar suavemente el cable de cinta sobre el panel de la pantalla. Si eso cambia esta línea, sabrá que el problema es la conexión entre el cable y el panel. Esto no se puede arreglar. A veces meter algo entre la carcasa del televisor y ese cable plano mantiene la presión suficiente para que hagan contacto.
Si esto no cambia nada, entonces lo más probable es que el problema sea la placa del controlador. No hay esquemas y las tarjetas no se pueden cambiar, pero un DIY'er como nosotros. Compruebe si hay algún componente quemado. Tal vez podamos encontrar uno y tratar de arreglarlo. De lo contrario, necesitará una nueva pantalla, ya que estas placas se consideran parte de la pantalla.
Si esto es demasiado confuso o si la siguiente traducción no tiene ningún sentido, añadir algunas fotos de sus tarjetas y la parte posterior completa de la TV (cubierta quitada, por supuesto) para que podamos ver y tratar de guiarlo más,
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 31
