Saltar al contenido principal
Repair information and troubleshooting for the 50, 55, or 60 inch UHD Samsung TVs with model number JU6800, released in 2016.
Preguntas 7 Ver todo
El encendedor de mi tv Samsung no enciende
El encendido de mi tv Samsung no enciende
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
@alalarco6351581 we need to get a bit more information from you. Let us know the exact model for your TV. Also, let us know if anything has happened to the TV prior to not turning on. Then let us know if your power LED turns on. We need to know what you have checked. Things like your electrical outlet as well as the power cord. Make sure those are working.
After all of this, you need to unplug your TV and remove the back cover. Then look at the circuit boards and check if there are any obviously damaged component. Anything looking odd is a subject :-) Take some good pictures of all of your boards and post those with your Question. That way we can see what you see.
If you are wanting to fix this, you will have to have a multimeter. That way we can guide you where and what voltages to measure. My prime suspect with anything like your symptoms is the power board, followed by a bad main bord. Easy enough to figure that out when we see what you have going on there.
Translation
@alalarco6351581 necesitamos que nos des un poco más de información. Indícanos el modelo exacto de tu televisor. Además, dinos si le ha pasado algo al televisor antes de no encenderse. A continuación, díganos si el LED de encendido se enciende. Necesitamos saber qué ha comprobado. Cosas como la toma de corriente y el cable de alimentación. Asegúrate de que funcionan.
Después de todo esto, tienes que desenchufar el televisor y quitar la tapa trasera. A continuación, mira las placas de circuitos y comprueba si hay algún componente obviamente dañado. Cualquier cosa que parezca extraña es un tema :-) Haz unas buenas fotos de todas las placas y publícalas junto con tu pregunta. Así podremos ver lo que tú ves.
Si quieres arreglar esto, tendrás que tener un multímetro. De esa manera podemos guiarte donde y que voltajes medir. Mi principal sospechoso con cualquier cosa como sus síntomas es la tarjeta de alimentación, seguido de un mal bord principal. Bastante fácil de averiguar que cuando vemos lo que tiene pasando allí.
https://es.ifixit.com/Gu%C3%ADa/Agregar+...
Fue útil esta respuesta?
Puntuación 0
Tiene luz Stand by apagada
Puntuación 0
1 comentario:
@ramonenriq78317 standby light off = Power supply (99% of the time :-)
- de
Añadir tu respuesta
Alalarco63@hotmail.com Arroyo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 20
Todo El Tiempo: 115
