no enciende el ventilador y el disco rigido
presiono el boton power y obserbo quw el ventilador no gira ni funciona el disco rigido como tampoco se enciende la pantalla
Es esta una buena pregunta?
@basiliobb sounds like your computer is having a power issue. You didn't tell us if there is any sign of life. Any LEDs that light up?
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see
Luckily Dell post their service manual as Owners manual. You can use this manual to work on your computer. It is in english and if you need it translated, I would suggest to utilize those free online PDF translation services.
Translation
@basiliobb Parece que tu ordenador tiene un problema de alimentación. No nos has dicho si hay alguna señal de vida. ¿Se enciende algún LED?
Empieza por lo fácil. Desconecta la alimentación del ordenador desenchufando el cable de alimentación del ordenador. Desconecta todos los dispositivos externos del ordenador. Retire la batería Ahora mantenga pulsado el botón de encendido durante unos 30seg-1min. Vuelva a conectar el adaptador de CA y compruebe si el ordenador da señales de vida.
Primero comprueba la fuente de alimentación. Asegúrate de que tiene los voltajes adecuados. Comprueba que los conectores no estén doblados, etc. Después, comprueba el puerto de carga. Límpialo de suciedad, etc. Utiliza un poco de aire para limpiarlo. Comprueba la toma de entrada de CC del portátil. Asegúrate de que no haya corrosión, residuos, etc. que impidan su funcionamiento. Si nada de esto funciona, coge un amperímetro y comprueba si tu portátil consume algún amperaje del cargador. A continuación, comprueba si la placa base recibe alimentación. Para eso, por supuesto, tienes que abrirlo. Publica algunas buenas fotos de lo que ves. De esa manera podemos ver lo que ves
Por suerte Dell publicar su manual de servicio como manual del propietario. Usted puede utilizar este manual para trabajar en su computadora. Es en Inglés y si lo necesita traducido, me gustaría sugerir a utilizar los servicios gratuitos de traducción de PDF en línea. Dell Inspiron 13z 5323 Manual
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 33
