No enciende ni carga
Mi Sony vaio pcg-4121gm no enciende ni recibe corriente del cargador, el cargador está correcto, que puede ser?
Es esta una buena pregunta?
@pacomingorance Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Also, use this wiki for a quick troubleshooting.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use these guides to work on your computer.
The PCG-4121GL uses a separate DC-In jack cable, which may be teh issue here. You are looking for something . So if you measure the voltages on the inside of your computer and your laptop doesn't get any power, replace this cable next.
Translation
@pacomingorance Empieza por lo fácil. Desconecta la alimentación del ordenador desenchufando el cable de alimentación del ordenador. Desconecta todos los dispositivos externos del ordenador. Retire la batería Ahora mantenga pulsado el botón de encendido durante unos 30sec-1min. Vuelva a conectar el adaptador de corriente y compruebe si el ordenador da señales de vida.
También, usa este wiki Sony Vaio PCG-4121GL Troubleshooting para una rápida solución de problemas.
Primero comprueba la fuente de alimentación. Asegúrate de que tiene los voltajes adecuados. Comprueba que los conectores no estén doblados, etc. Después, comprueba el puerto de carga. Límpialo de cualquier suciedad, etc. Utiliza un poco de aire para limpiarlo. Comprueba la toma de entrada de CC del portátil. Asegúrate de que no haya corrosión, residuos, etc. que impidan su funcionamiento. Si nada de esto funciona, coge un amperímetro y comprueba si tu portátil consume algún amperaje del cargador. A continuación, comprueba si la placa base recibe alimentación. Para ello, por supuesto, tienes que abrirla. Utiliza estas guías Sony Vaio PCG-4121GL para trabajar en tu ordenador.
El PCG-4121GL utiliza un cable DC-In separado, que puede ser el problema aquí. Estás buscando algo como esto. Así que si mide los voltajes en el interior de su ordenador y su portátil no recibe ninguna energía, reemplace este cable a continuación.
Fue útil esta respuesta?
El puerto de carga, la batería, el chipset, algunos protocolos que tienen algunos ordenadores para evitar dañar la batería.
También es posible que hayas testeado el cargador en otro dispositivo de menor corriente y que el cargador no esté transportando tanta energía como pide el equipo, pero sí el otro dispositivo que hayas probado, pero eso es muy poco frecuente.
La batería es poco probable también, ya que dices que no recibe corriente, por lo que entiendo que no se mantiene encendido con el cable puesto.
Probaría con un multímetro para identificar si es el puerto de carga, y si no, el chipset a lo largo del circuito hasta la batería.
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 98
