le cayó agua en el teclado y ya no enciende, ¿por dónde empiezo?
Le cayó agua en el teclado y ya no prende :(
Es esta una buena pregunta?
Acude a un servicio tecnico de PC portatiles y que presupuesten si tiene reparación, es muy probable que no sea reparable.
Fue útil esta respuesta?
@adrianaislas besides the great answer provided by my esteemed colleague @carloslope27326 I would suggest you give this a try. The reason for that is because over here (USA) a lot of repairers do not take on any water damage repair, since those can be extensive. This answer is just meant as an alternative to teh prior great answer.
Disassemble your laptop by using these guides and this video should work for the motherboard. Now check your motherboard for any sign of corrosion. Look for major corrosion, evaluate the pins on all the connectors and teh flex cables etc,. Next you will need to remove all the EMI shields as well as teh fan and heatsink. Once you get any gross contamination cleaned, use 96%+ isopropyl alcohol and clean your parts some more.
For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your laptop parts as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. The importance here is the cleaning. It would of course be best to get it professionally cleaned
For as long as you have not cleaned your board, everything is just a guess. Once cleaned check the board for any missing, charred or are otherwise "odd looking". you can always post pictures of your board etc. with you Question. That way we can see what you see. Definitely take some pictures of teh motherboard (both sides) That way we can at least identify it. Once everything is properly cleaned and checked for damage, reassemble your Nitro and reevaluate by trying it out.
You may also experience that the keyboard is shorted out. In that case you will need to consider a new topcase. Try a USB keyboard if needed. Again, you won't know until you at least give it a try. Even using used parts to repair you laptop should be cheaper than having to buy a new one. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@adrianaislas además de la gran respuesta proporcionada por mi estimado colega @carloslope27326 yo sugeriría que le diera una oportunidad. La razón de ello es que aquí (EE.UU.) una gran cantidad de reparadores no toman en cualquier reparación de daños por agua, ya que estos pueden ser extensas. Esta respuesta es solo una alternativa a la anterior.
Desmonta tu portatil usando estas guias Acer Nitro 5 AN515-53-52FA y este video deberia funcionar para la placa base. Ahora revisa tu placa base en busca de cualquier signo de corrosión. Busca corrosión importante, evalúa los pines de todos los conectores y los cables flexibles, etc. A continuación, tendrá que quitar todos los escudos EMI, así como el ventilador y el disipador de calor. Una vez que haya limpiado cualquier contaminación gruesa, utilice alcohol isopropílico al 96%+ y limpie sus piezas un poco más.
Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero sigue siendo pertinente para las partes de su ordenador portátil también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en áreas que causarán problemas más adelante. Lo importante aquí es la limpieza. Por supuesto, lo mejor es que lo limpie un profesional.
Mientras no haya limpiado la placa, todo son suposiciones. Una vez limpia la tabla, compruebe que no falte nada, que no esté carbonizada o que tenga algún otro "aspecto extraño". siempre puede publicar fotos de su tabla, etc. con su pregunta. De esa manera podemos ver lo que ves. Definitivamente tomar algunas fotos de la placa base teh (ambos lados) De esa manera podemos al menos identificarlo. Una vez que todo esté bien limpio y comprobado que no hay daños, vuelva a montar su Nitro y vuelva a evaluarlo probándolo.
También puede ocurrir que el teclado esté en cortocircuito. En ese caso tendrá que considerar un nuevo topcase. Pruebe con un teclado USB si es necesario. De nuevo, no lo sabrás hasta que al menos lo pruebes. Incluso utilizar piezas usadas para reparar tu portátil debería ser más barato que tener que comprar uno nuevo. Tenga en cuenta que los daños por agua son los más difíciles de solucionar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 54
