@adrianavan56935 my esteemed colleague and friend @carloslope27326 is a wise man and is most certainly right with his great answer. Remember that a lot of repair places do not work on water damaged devices. That is because it takes a lot of time and will not make any money for their business. Since the bottom line here is, that you may have to replace the motherboard anyway, I would suggest you at least give it a try and see if you can resurrect your tablet.
Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
For now, you must stop continuing to try to charge, sync or otherwise use your tablet. This potentially can make a bad situation worse. This may further damage your tablet.
The very first step I would take is to disassemble your tablet. Use these guides Lenovo Tab 4 8 to help you disassemble it. Take a close look at all components and connectors. Truly assess the damage. Look for any major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields from the motherboard. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. If you have any questions about any part, you can always post some pictures of it with your Question. That way we can see what you see.
For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your tablet as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the tablet to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it professionally cleaned with an ultrasonic cleaner. After that you must replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your tablet and re-evaluate for any further damage.
For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage. Remember, Rice does not work.
Translation
@adrianavan56935 mi estimado colega y amigo @carloslope27326 es un hombre sabio y sin duda tiene razón con su gran respuesta. Recuerde que una gran cantidad de lugares de reparación no trabajan en dispositivos dañados por el agua. Eso es porque se necesita mucho tiempo y no va a hacer ningún dinero para su negocio. Dado que la conclusión aquí es, que puede que tenga que reemplazar la placa base de todos modos, yo sugeriría que al menos darle una oportunidad y ver si se puede resucitar a su tableta.
El arroz no funciona. No hace absolutamente nada para ayudarle con esta reparación. Todo lo que hace es perder el tiempo y desperdiciar comida. Compruebe aquí https://www.ifixit.com/News/30047/rice-i... para más información sobre esto.
Por ahora, usted debe dejar de seguir tratando de cargar, sincronizar o utilizar de otra manera su tableta. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su tableta.
El primer paso que yo daría es desmontar tu tablet. Utiliza estas guías Lenovo Tab 4 8 para ayudarte a desmontarla. Observa detenidamente todos los componentes y conectores. Evalúa realmente los daños. Busque cualquier corrosión importante, evaluar los pines en los conectores, etc,. Eche un vistazo a todos los conectores, así como a los extremos de los cables. Usted tendrá que quitar todos los escudos EMI de la placa base. Si no quita los escudos, no está limpiando la placa. Una vez que haya limpiado la contaminación gruesa, utilice 90%+ alcohol isopropílico y limpie sus partes un poco más. Si tienes alguna duda sobre alguna pieza, siempre puedes colgar alguna foto con tu Pregunta. De esa manera podemos ver lo que ves. https://es.ifixit.com/Gu%C3%ADa/Agregar+...
Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero sigue siendo pertinente para su tableta también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en áreas que causarán problemas más adelante. No es necesario dejar secar la pastilla durante un día. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua.
Lo importante aquí es la limpieza. Por supuesto, lo mejor sería limpiarla profesionalmente con un limpiador ultrasónico. Después de eso debe reemplazar la batería. Esto es un deber y no una opción. Fallará si no te ocupas de ella ahora. Después de eso, vuelva a montar su tableta y vuelva a evaluar si hay más daños.
Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños causados por el agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño. Recuerde, el arroz no funciona.
