audio jack not working
repairing the audio jack - what do i have to remove to access and repair the audio jack. It no longer provides an audio signal to headphones plugged into it.
Es esta una buena pregunta?
I would just get a USB-A DAC adapter like CableCreation USB Audio Adapter as replacing the iMac headphone port is a lot of work as you need to take the logic board out to gain access to the port which is glued to the case so you can get a heat gun to it to soften the glue. Follow this guide Reemplazo de la placa lógica de iMac Intel 21.5" EMC 2889 and here’s the needed part Headphone Socket and Cable
Fue útil esta respuesta?
Thanks for providing bot a practical answer (which I will go for) as well as a link to the full solution which looks a bit difficult for me
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 211
