Why is my laptop not turning on?
The laptop was on, put it to sleep for about 5 minutes went back to turn it on complete blank. The power button was still on so I waited for it to start but nothing. I pressed the power button to forcefully turn it off. Once off I turned it back on, the power button turned white instead of blue and the caps lock and number lock showed that they were on as the light was on. But after a minute or so it turned back off alone.
Since then it doesn't turn on, just the power button is white and then turns back off alone in less than a minute
Es esta una buena pregunta?
5 comentarios
Hi @lea66415,
Does it also do this with the charger connected, you didn't say?
- de jayeff
yeah it does with charger connected as well.
- de lea
@lea66415
Does the laptop indicate that it is charging when you connect the charger?
If so just let it fully charge before attempting to turn the laptop on, with the charger still connected and then check what happens.
It may be that the battery was very low and the charger can't do both i.e. charge a very low battery (faulty?) and run the laptop at the same time so nothing happens when you try turning it on.
- de jayeff
Yes it indicates that its charging when connected to the charger.
I did that but same thing happened.
- de lea
Hi @lea66415
Did you happen to get it working? I’m having the same exact issue. Thanks :)
- de Aidan Amo
