Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información sobre el dispositivo y la reparación del sistema de altavoces Behringer Eurolive B212D.
Why does my speaker quit after about an hour?
My speaker works great for approximately an hour or so then stays cutting in and out then stops working completely.
Update (10/21/23)
Imagen
I found that one of the leads on coil "L1" has a bad solder joint. This would most likely be why it would work for a while then cut out as the unit heated up. I will resolver and give it a go.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@bruce66667 this "speaker works great" combined with that "cutting in and out then stops" leads me to believe that this is a power board issue. Possibly a bad MOSFET or other component. Open it up and take a look at the power board Sustitución de la placa de circuito impreso de alimentación del Behringer Eurolive B212D for any discolored, odd looking component etc. Post some good pictures of it with your Question. That way we can see what you see. Agregar imágenes a una pregunta existente
Imagen de Behringer Eurolive B212D Placa de circuito impreso de alimentación
Guía
Dificultad:
Moderado
30 - 45 minutes
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Fue útil esta respuesta?
Puntuación 1
1 comentario:
@bruce66667 yes, that would definitely be an issue. Let us know if resoldering the inductor resolved the issue.
- de
Añadir tu respuesta
Bruce estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 334
