How to replace radiator drain petcock valve
drain valve wont turn open and needs to be replaced. How to get old one out and install new valve
Es esta una buena pregunta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 92
Hi @dougs57198,
What is the year and engine of the vehicle?
- de jayeff
2003 std 5.7 base coupe with 1/4 turn white plastic valve which a sq driver just spins and valve does not open or come outwards. I have done it before OK a few years ago.
- de Doug .S
@dougs57198
Not sure if access is easy but can you use a pair of multigrips and try pulling the drain cock out as you're turning it?
- de jayeff
will give it a try, but now getting cold and I'm likely to delay for a while. Thanks for replies.
- de Doug .S
