Hi @gregarkwri91283
Check the colour of the LDI (liquid damage indicator), located in the SIM tray slot. Click on Liquid or corrosion evidence.
If the LDI is pink then the oil has entered into the phone and has possibly caused more problems
The impurities in the liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and any liquid residue. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the liquid may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after doing all this the phone might work OK
Here is the ifixit Samsung Galaxy S22 Ultra repair guide that may help
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair.
2 comentarios
Also, I have not turned it back on in days so I don't know the extent of the damage if any. I'm assuming turning it back on is not advisable and I'm considering opening it to examine it for oil. But seeking first maybe some guidance on if that's necessary or smart
- de Greg Arkwright (gregark28)
i have an update. I turned it on by accident and noticed that it seemed to work fine and there was nothing wrong with it. However after a while the touch screen stopped working properly. So, now I'm looking for advice on what to do at this point based on my phone model and situation. Thank you.
