H61mk no display problems
Es esta una buena pregunta?
I bought a pc with that same asus motherboard. Hopefully this helps. When I purchased it, it all worked well, but I bought someRAM and installed it, but it wouldnt turn on unless I removed one of the ram. So you might wanna remove one of your ram kit from one of your 2 slots. Hopefully that works. Im still trying to figure out how to fix mine so any onput would be greatly appreciated.
Fue útil esta respuesta?
Hi @occarrillo,
The motherboard supports a maximum of 16GB ram over two slots i.e. 2 x 8GB,
The ram is DDR3L-1600 CL=11 NON-ECC UDIMM 240-pin 1.35V 2Rx8 PC3-12800
How much ram was originally installed?
Did you only change one ram module to increase the amount of memory or both?
Usually you need both modules to have the same latency i.e. CL=11 to avoid any problems,
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 34
Todo El Tiempo: 204
Hi @prandfamily,
If the PC booting into the operating system but without a display i.e. can you hear the Windows welcome sound etc?
Is the monitor connected to the motherboard's onboard video output port or is there a GPU card installed on the motherboard?
- de jayeff
