Saltar al contenido principal
Lanzado el 20 de septiembre, el móvil abanderado de Apple en 2019 dispone de una pantalla OLED de 5.8", una cámara trasera de triple lente y una autonomía ampliamente mejorada. Es el sucesor del iPhone XS.
Preguntas 156 Ver todo
After falling into sea water my I phone 11 pro is not working.
  • My take my phone with me to swim in a sea beach fir 1 minute after coming out it stop working but it was only 1% charger that time so I came back home and connect the charger but this didn't work and now from that day it's not working even I take it to a mobile repair shop also but they said it will not work anymore can u please help me
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi @mirowais
You could try to fix it yourself although it may already be too late or perhaps find another repairer who is willing to try and fix it but don't be surprised if they also say no it cannot be done.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is ifixit iPhone 11 Pro guide that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
mir Owais estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 46
