Saltar al contenido principal
Fix your iRobot Roomba e5 vacuum with these replacement part DIY repair guides. Model Number e515020
Preguntas 4 Ver todo
Runs only short period of time
Runs only 10 minutes after charged, usually run at least 1 hr.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
There's an option to limit run time on the app setup. If you've ever used the irobot home app with this device, I'd start by making sure it's not set to limit run time in the app. If not, probably consider replacing the battery pack, which is a pretty simple task on these.
- de
Agregar un comentario
1 Respuesta
Likely, the battery is having an issue. When it stops working, does the battery take the full time to charge? Otherwise it could be an overheating motor or something like that
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Barry Meltzer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 160
