Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La cuarta generación del Fairphone, fabricada por la empresa social del mismo nombre. Lanzado en octubre de 2021.
Why can't I extract the display?
Approximately two months ago, I accidentally partially destroyed the display of my Fairphone 4, and after various struggles in terms of buying and selling, today I finally managed to get a replacement ready to be installed.
I prepared myself and started the official video available on YouTube. Fully charged battery, screw container, cloth, plastic card, and screwdriver at hand. Everything is ready.
So, I begin, initially struggling a bit with the trickier screws, but soon I find the method. However, it doesn't seem to be enough because when I try to remove the screen, even though all eight screws have been removed, the bottom part, below the SIM slot, remains firmly in place.
And that's the story of how all the waiting has been wasted so far.
I also tried to disassemble the rest, but the bottom part, secured with six silver screws, even after removal, doesn't alleviate my difficulty, while the side part has hexagonal screws, so a crosshead screwdriver doesn't seem to be enough. Now I have reassembled everything except for the eight screws attached to the screen, to see if someone responds today.
Imagen
Imagen
Imagen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
The video I'm referring to is this one:
https://youtu.be/SUJERxuYGLI?si=JA-kqw6M...
- de
Agregar un comentario
2 Respuestas
@carmelo40109 we are not sure what video you are following. I would have suggest that you use the guide from here Reemplazo de la pantalla del Fairphone 4 Going by that, all you should need is a Phillips #00 screwdriver. Post some pictures of what display you have and of the screws etc. that are giving you trouble.
Agregar imágenes a una pregunta existente
Imagen de iFixit
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Imagen de Fairphone 4 Pantalla
Guía
Dificultad:
Fácil
10 - 20 minutes
Fue útil esta respuesta?
Puntuación 0
I finally solved it:
all I had to do was to apply more force when extracting the body at the bottom.
I followed the procedure and everything went as planned.
Whoever has the opportunity can now close the topic.
Puntuación 0
1 comentario:
Choose this post as the answer, and the topic will close.
- de
Añadir tu respuesta
Carmelo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 613
