In cpc power supplying is not coming
In cpu power supplying is not working
Es esta una buena pregunta?
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. Agregar imágenes a una pregunta existente
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 34
