Saltar al contenido principal
no light on front controls and the lights out in the refrigaroter
have done everthing you have said the refrigaroter is still working just no light on front controls and the lights out in the refrigaroter is it the front control board are main control board model number is mfi2568aes Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @larrychilcutt
Just clarifying if the display still works on the control panel?
If it does try entering the service test mode as described on p.4 and then perform service tests #151, #152 & #153 as described on p.5 and check what happens.
If it doesn't then most likely the problem is on the main board as that is where all the relays that are operated/released to turn on lights etc are situated and also where the power is distributed from - see the schematic on p.1
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Larry Chilcutt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 25
