Saltar al contenido principal
Información de reparación y desmontaje del teléfono inteligente Android Galaxy A32 5G de Samsung, lanzado en febrero de 2021.
Preguntas 20 Ver todo
Why is my phone charging slow?
When I plug the charging cable into the A32, it says slow charging and it doesn't charge at all, I tried with all chargers from my house and the original one.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
2 Respuestas
Loose contact of charging connector or old lightning cable makes such a case in my experience. Check this first if same then you may replace the charging connector.
Fue útil esta respuesta?
Puntuación 0
@maximilians4891 since you tried all kinds of different chargers, we are going to make the assumption that the charger is not the issue. In that case you want to consider a. the battery. Remember that a dead battery cannot hold or a take a charge. Check your battery connection. Here are the instructions for the battery.
Reemplazo de batería del Samsung Galaxy A32 5G
After that, you want to check according to the flowchart
and here is where you will find the components to be checked.
Puntuación 0
2 comentarios:
The battery health is good, just discovered that it is not connecting to pc and it's only charging from it, and still slow
- de
@maximilians4891 Can you try cleaning out the charging port gently with a non-metal object? Pocket lint can get into ports and prevent the data pins from making contact.
- de
Añadir tu respuesta
Maximilian Stafiu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 22
Todo El Tiempo: 1,356
