Saltar al contenido principal
Side-by-side refrigerators feature two tall, narrow compartments that span the full height of the unit, with one side dedicated to the refrigerator and the other to the freezer.
Preguntas 2 Ver todo
Freezer is getting too warm
I have a GE Monogram 42" Built in, model zisb42dyb. The freezer will get to -10 degrees and go all the way to 40 degrees. I have replaced the Defrost Timer and the Defrost Thermostat. I also replaced the Condenser Fan for a different issue. The issues continue.
I have realized that the evaporator fan does not operate consistently. It will operate properly sometimes and the freezer will drop to -10, other times it comes on and goes off within 2 seconds, not moving the cold air into the freezer compartment. I believe that is the issue. But, I don't know what controls the evaporator fan and sends a signal to turn on or off. Please help if you can.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi @alexrivlin
If the refrigerator temp is OK but the freezer temp isn't, check that the dispenser door assembly is OK. (supplier example only to show part and has a video as well).
if it isn't closing properly it may be allowing warmer air to enter the freezer compartment thereby raising the temp.
If it is faulty and needs replacing, search online for WR17X11653 to find suppliers that suit you best.
Update (08/01/23)
@alexrivlin
Not sure if they're the same as a ZISB42 series but looking at the ZIS42 series service manual there is a delay thermostat associated with the evap fan, perhaps that is faulty. (see following page in manual I linked for location to check).
The parts suppliers I checked for your model don't mention it as a spare part, (they also don't mention it for the ZIS42 models either) only the defrost thermostat,
Perhaps it has markings on it that will help to find a replacement if it is faulty. Reading the description of operation and seeing an image of the thermostat it seems very similar to a bi-metal defrost thermostat in that usually they also operate at ~45°F to open the defrost heater circuit and close again at ~25°F to re enable the circuit after a defrost cycle has been completed to close the heater circuit again in readiness for the next defrost cycle.
You may even find that it is identical to the defrost thermostat in the freezer. If it is search online for WR50X45 to find suppliers that suit you best.
Here's a link that shows how to test bi-metal thermostats.
Imagen de WR17X11653 - GE Refrigerator Dispenser Ice Chute Door
Producto
$15.99
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thanks, The entire unit gets warm when the evap fan turns off at the times that it should stay on. I am not sure what controls the evap fan. Which is where I am stumped.
- de
Añadir tu respuesta
Alex Rivlin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 134
