Is there a way to fix a broken rear tire, part number - 330072007?
The inner part of one of my Ryobi lawn mower's rear tires is cracked. Replacement isn't possible until 09/14/23. Is there a way to fix the tire?
Es esta una buena pregunta?
This vendor (example only, if Ryobi does not have) appears to have the replacement wheel in stock: https://www.partswarehouse.com/Homelite-...
Could you share a picture of the cracked wheel? Agregar imágenes a una pregunta existente That may help with repair ideas; a plastic wheel may be difficult to repair adequately for this application).
I looked to see if anyone has made a 3D print available of this wheel and didn't find one (my idea being that you could get a service to print you a new plastic wheel--like this fix BCG800XL Grinder Jamming due to Worn Impeller -- that might last at least a while (but probably not be cost effective or durable enough in this application as a long term fix).
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Guía
Dificultad:
Moderado
10 - 35 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 205
