Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The screen doesn't work
I put water on my screen and after sometime the screen didn't work
Es esta una buena pregunta?
Puntuación 0
1 comentario
@abdallahhashem the water shortened out your screen. we will need to know your exact computer model so we can at least try to help you fixing it.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Not good. Screens should only be cleaned with a DAMP cloth. If water ran down the screen, then it may have caused a short or corroded connections. The only hope is that after the water dries it will work. Otherwise, you will need to disassemble the screen and see if you can determine where the problem is. It may not be fixable without a new screen. That may or may not be economically viable.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Abdallah Hashem estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 307
