Selfie camera broken after back glass replacement
I replaced the back glass on an iPhone 14 pro. I used a laser machine to burn away the adhesive so I didn’t have to muscle with the phone too much while removing the glass. After the repair, the selfie camera didn’t work. Everything else with the phone works perfectly. Here are the steps I’ve taken to trouble shoot so far:
- Replaced the GPS antenna sensor (thought I could’ve damaged it because it pokes through the frame)
- Replaced the camera flash flex cable
- Replaced the front camera assembly
- Swapped out the front camera only (had to disassemble the front camera assembly with a Dremel)
I did notice the original selfie camera had a small scratch on the flex cable pictured below. Thought replacing would for sure solve the problem but now I’m stuck.
Es esta una buena pregunta?
I’d love to talk to you about your back glass replacement if you had some time
- de Jusitn Blain
I definitely have time, sorry I just saw this
- de Ben Tratt
Update, tried the DIY. Punctured my battery. Took it to batteries plus and they gave me a new battery try and back glass almost half as expensive as Apple
- de Jusitn Blain
hey i have the same thing that just happened to me, did you end up figuring it out? if you did get back to me because i don’t wanna buy a bunch of parts when it could be a easy fix. Thank you!
- de kelton
